Patroller door mod
Patroller door mod
Post by 8170 »
There was a post on the old forum with some good pictures. Any chance that someone saved those pictures? I am starting my doors and could really use those as reference material. Thanks.
Aircraft Type: 48 140 C90
Re: Patroller door mod
Post by 6898 »
David Lowe or Lorraine Morris will have those i can only imagine.
Post by 8170 »
Im having a hard time reading the print so I am looking for the dimensions for the cut out. I am going to redraw it and make a template. My goal is to put together a tutorial and simplify the process. I will probably change a few things to make it easier and then submit a 337.
Did I send you the drawings?
Mike
Post by 5115 »
Joe I sent you all files I had on the subject. Enjoy!
Martin Tanguay
Post by 8170 »
Mike,
Yes I have the drawings you sent. I am just having a hard time reading them.
Post by 8170 »
Thank you Martin
8170 wrote: ↑Tue May 22, 2018 10:26 pm Mike,
Joe,
I took the drawing info on a thumb drive to a local blueprint shop, and they were able to enlarge the drawings to a standard size for easier viewing.
8240
Occupation-Interests: Pilot, Southwest Airlines
Post by 8240 »
Howdy! Im interested in having the patroller doors as well. Any chance one of yall could send me the drawings? Im supposing this is done via 337? Any advice is appreciated. Thanks, Jim.
Rob Swanland
Aircraft Type: C-140A
Post by Rob Swanland »
8170 wrote: ↑Sun May 20, 2018 2:03 pm There was a post on the old forum with some good pictures. Any chance that someone saved those pictures? I am starting my doors and could really use those as reference material. Thanks.
Just a quick update... all of the pictures and other documents from the old forum are preserved. The problem is that there are approximately 11,000 of these attachments, many of which have no value. I am working on this but it is a project that will take hundreds of hours. My goal is to take the posts and the image attachments from the old forum and organize this information is a useful fashion - I haven't yet figured out how I want to do this, but it will happen. --Rob
