Packers around fuel tank filler
Occupation-Interests: Mechanical and Structural Designer.
Post by 7133 »
Timber packers around the fuel tank fillers, should these come right up to the underside of fabric, or sit just below?
Re: Packers around fuel tank filler
They support the fabric, which is glued to the wood.
7133
Post by 7133 »
Thanks John.
Seems logical but wanted to check.
Cheers
Michael
Post by 6298 »
6643 wrote: Sun Feb 24, 2019 7:52 pm They support the fabric, which is glued to the wood.
I agree!
Check your gas cap fit, before you install your fabric........... :shock:
