C-140A Tire Pressure
Aircraft Type: C-140A
Post by 8156 »
Recently purchased a 1950 C-140A and would like to find out what the recommended tire pressures are. All are standard size tires and it has a Scott 3200 tail wheel.
About 90% of my flights are out of grass strips but I am starting to spend more time on hard surfaces.
Appreciate any advice...
Dennis
Aircraft Type: '48 140
Re: C-140A Tire Pressure
Post by 6339 »
I keep mine at 24 for the mains and 35 for the 3200 tailwheel. I operate almost exclusively on pavement.
Mine is a 48 with the forward swept gear.
Steve
I can tell you the 120-140 operation manual says 16psi, but I don't have a 140A operating manual.
I run 16psi in my 8.00's and primarily do wheelies on asphalt (I miss my old grass strip) with no extenders on early legs.
16-20psi on the mains.
35 on a Scott 3200 tail wheel.
I run 7:00 X 6 mains and fly off grass quite a bit.
Post by 6277 »
There's a graph somewhere on TP for the Scott 3200. It's small and hard to read but is based on tail wheel weight. 30 works fine for me. I keep the mains at 27 or 28. When they get low (around 20) it's hard for me to push the plane out of the hangar with full fuel.
Post by 8170 »
16-18 on my 6.00x6 and 15-30 max on my 8.50s
