C-85 stroker
C-85 stroker
Post by 8157 »
So I bought a C-85 stroker from Don's Dream Machines. I am still in the break-in period, using mineral oil. The extra power is quite noticable. My 140 practicaly leaps off the runway and I am getting an additional 150 to 200 fpm on climb out. Leveling off into cruise, I have have to be careful avoid over-reving the engine. I have to back off the power considerable to keep below the red line rpm. Does anyone else have any experience with the stroker engine?
Re: C-85 stroker
Sounds like you need to increase the pitch on the prop. Do you know what model and pitch it is? What is your static RPM?
Re: C-85 stroker
I have a different question. Did you buy the engine recently? The reason I ask is I had completely lost track of Don, I thought he closed up shop and disappeared?
Re: C-85 stroker
529 wrote: Thu Mar 07, 2019 8:06 pm I have a different question. Did you buy the engine recently? The reason I ask is I had completely lost track of Don, I thought he closed up shop and disappeared?
Don Wade over in Bessemer, AL bought Don Sword's "operation" a while back...best I recall it's still going by "Don's Dream Machines". I understand that Don Wade brings the same kind of experience & expertise to the powerplant shop that Swords earned fame for, plus his shop does a lot of classic restoration work in addition to engines. Mac
Aircraft Type: 1946 C120
Re: C-85 stroker
Post by 8233 »
I went to one of the Small Continental workshops at Oshkosh last year and both the "Dons" were giving the presentation and answering questions.
Re: C-85 stroker
Ok, thanks I did not know that. Now I do. :D
8157
Re: C-85 stroker
Post by 8157 »
I have only good things to say about Don Wade and his crew.
8322
Re: C-85 stroker
Post by 8322 »
I’m pleased with mine, though I’ve not known her any other way... but no I don’t have a problem keeping her from red line...
What do you plan on running at cruise rpm wise? I find just slightly north of 2400 she seems the smoothest...
I’ll check my prop size for ya I forget off top of my head..
Ray
8157
Re: C-85 stroker
Post by 8157 »
I fnally had time to look this up. My prop is an MX76AK-2-44
