Tailspring Hole, Help
Post by 6319 »
I'm ordering a Tailspring from Univair after reading all the helpful info on this site. I asked about attachment holes due to my AN6 fuselage Bolt and Scott 3200 Tailwheel 7/16 Bolt. Early s/n 121749
Univair say the fuselage attach end of the spring set has a 5/8 dia hole. Measured and verified 5/8 hole for a 3/8 bolt.
Is this correct ??
4006
Occupation-Interests: Electrical & Electronic Design & Troubleshooting
Re: Tailspring Hole, Help
Post by 4006 »
Is this correct ??
Yes, Insert a piece of rubber hose in the spring holes before inserting the bolt.
viewtopic.php?f=10&t=134
Mike Gourd, Centredale Airport CDL8
6319
Post by 6319 »
Thanks, Mike. When I re-visited the article saw the hose. Found the 1/4 pads at WagAero.
