Window latches
Aircraft Type: C-140 (sold)
Re: Window latches
Post by 8342 »
The window will go up to the wing and stay there until landing.
We used to open it while doing aerial photograph so we could get a better picture by not shooting thru the window.
Spent hours with it open with no ill effects.
Aircraft Type: Cessna 120
Re: Window latches
Post by 7896 »
Thanks for the info. I'll give it a try when the hot weather returns.
Michael Haas
'46 120 - N76219
Home Base: W96 (Quinton, VA)
Occupation-Interests: Pilot
Re: Window latches
Post by 8230 »
I can verify it rises and just hangs under the wing... We used to do that when in flower bombing contests.. :D
DC_Wolfe
wolfeairshows.com
8359
Re: Window latches
Post by 8359 »
I flew with the window open tonight, it was awesome. Surprisingly not as windy as I expected.
8359
Re: Window latches
Post by 8359 »
Also, to add to this discussion, my windows have VW bus latches, they work great. They don't prop the window, but as discussed the wind holds it up.
VW Bug Bus Right Vent Wing Window Latch Lock 113837640a - eBay Cheap too.
Re: Window latches
Post by 6183 »
8359 wrote: ↑Fri May 03, 2019 1:56 am Also, to add to this discussion, my windows have VW bus latches, they work great. They don't prop the window, but as discussed the wind holds it up.
How did you attach it to the glass?
Re: Window latches
Post by 5115 »
I have the same, they are great.
If you look carefully at the picture, you will see the main bracket is U shaped and it is as thick as the thickness of the window frame and you rivet it to the frame. Easy, not original like the real Cessna latch, but I like to see the window wide open with the elbow outside.
Great picture.
Martin Tanguay
8359
Re: Window latches
Post by 8359 »
6183 wrote: ↑Fri May 03, 2019 9:52 amHow did you attach it to the glass?
As described by Martin above, but I'll get you some more detailed photos this weekend.
8424
Name: Steve A H
Aircraft Type: 1950 C140A
Occupation-Interests: Retired
Re: Window latches
Post by 8424 »
Is a 337 necessary to use the VW latch?
Thanks.
Steve
Re: Window latches
Post by 6183 »
8359 wrote: ↑Fri May 03, 2019 12:13 pm
Ahh, okay. Thanks for pointing that out, I can see that it's attached to the frame. As Steve asked did you cover the installation with a 337?
