I recently purchased a 120 and it is equipped with CHT for the two rear cylinders. While flying it I noticed one of them has the tendency to top 400 dF during climb, even if I try climbing at 85-90 MPH. Oil temperature remains in line during this time and CHT is fine in level flight. OAT was 32-33 dC on the ground.
The airplane had at one point spent several years of its life in Wisconsin before coming south, is there a chance there is some sort of winterization kit applied that may be heating things up? I noticed the manual notes a “summerization kit,” which as I understand it is a lip on the trailing edge of the bottom cowling which helps cooling - I noticed this lip tends to be present on other model airplanes of the same era.
Are there any suggestions as to how I may check to ensure my temperatures are controlled? I can look at the baffling but the issues only present themselves during climb; my initial impression is I may not gain much there.
Engine cooling
8451
- Name: Daniel
Re: Engine cooling
C-85? The limit is 540 degrees. If the reading makes you uncomfortable, cover the gauge with something.
(The summerization kit also includes inter-cylinder baffles.)
8451
- Name: Daniel
Re: Engine cooling
Yes, C-85. I know the strength of aluminum drops off quickly above 400 dF, prompting my concern, certified redline notwithstanding.
8359
- Name: Tamer A
Re: Engine cooling
I've been thinking about this as well, I hit 400*F pretty easy in my O-290, however my oil temp never peaks 170-180*F. I know Mike Busch recommends no more than 400*F, but he is a self proclaimed longevity nut.
My concern is that my oil temp doesn't seem to be getting high enough. Lycoming recommends at least 185*F (up to 210*F) for oil operating temp in order to help burn off any moisture that gets into the oil. I've never been able to get it up that high. And I'm not sure I want to with my CHTs near 400*F.
Seems like an impossible task to me, maybe if I ditched the oil cooler.
Re: Engine cooling
Have you calibrated your oil temp system?
- Aircraft Type: C-140 (sold)
Re: Engine cooling
What temperature is the other probe indicating?8451 wrote: ↑Mon May 20, 2019 8:16 am I recently purchased a 120 and it is equipped with CHT for the two rear cylinders. While flying it I noticed one of them has the tendency to top 400 dF during climb, even if I try climbing at 85-90 MPH. Oil temperature remains in line during this time and CHT is fine in level flight. OAT was 32-33 dC on the ground.
It may be just an indication issue.
I would swap the probes around to see if it follows.
- Name: Tamer A
- Name: Daniel
Re: Engine cooling
Rick, one probe is indicating about 410-420, the other is about 360.8342 wrote: ↑Mon May 20, 2019 8:11 pmWhat temperature is the other probe indicating?8451 wrote: ↑Mon May 20, 2019 8:16 am I recently purchased a 120 and it is equipped with CHT for the two rear cylinders. While flying it I noticed one of them has the tendency to top 400 dF during climb, even if I try climbing at 85-90 MPH. Oil temperature remains in line during this time and CHT is fine in level flight. OAT was 32-33 dC on the ground.
- Name: Martin Tanguay
Re: Engine cooling
Put both probes in boiling water and see if they both get to 212F.
There could be some good differences between the front cylinder temp and the rear ones.
Lots of things can affect cylinder temp. Baffling, cable or harness in the airflow, preventing proper back cylinders cooling, etc.
You need to know if both probes are good to start with.
Martin Tanguay
