Source for elevator stop bolts
Aircraft Type: 1947 140 C85
elevator stop bolt question
Post by 4323 »
I know this was brought up before, but where can I find some? I have looked at Aircraft Spruce and Wicks.
Thanks, Bob Newell
4323
Post by 4323 »
I am looking to replace the bolts with new ones. They are listed in the manual as part number
0431141 Bolt - Elevator Bell Crank Stop. I didn’t see them at Aircraft Spruce or Wicks.
Thanks, Bob Newell
8175
Name: Larry Lowenkron
Aircraft Type: Cessna 140A
Re: Source for elevator stop bolts
Post by 8175 »
Winner Aviation in Niles, OH has 0431141-1. I found them doing a part number search on Controller.com.
Not sure what the dash 1 is, but might be worth a call to them.
https://www.controller.com/parts/aircra ... pst=starts
Larry Lowenkron
C140A N5641C
Are they 10-32 bolts? If so, I have an NAS428 stop bolt that works for the ailerons and should work there, too, except you may have to shorten them. They are 1-1/4" long and threaded over the whole length of the bolt.
4323
Post by 4323 »
Thanks Larry and John, I haven’t had time to check on them yet. I should be able to look into it next week.
Bob Newell
I checked the parts catalog and they screw into a 10-32 nut, so the ones I have should work, unless the heads drilled for safety wire.
7633
Aircraft Type: C120
Occupation-Interests: Aircraft Technician
Post by 7633 »
They’re made from an AN3H-11A bolt with threads cut most of the way up the shank. The -1 is the same except made from an AN3H-15A. There is also a -2 and a -4, same but even longer AN bolts.
Jeff
Stop bolts have no raised markings on the head. Also, if Cessna is making them from AN hardware, then I'm guessing they're re-plating them after.
7633
Aircraft Type: C120
Post by 7633 »
I'm sure they were, have to justify them being so expensive somehow!
The -1 bolt does supersede to a NAS428H3A12 on the textron website.
Jeff
7633 wrote: ↑Sat May 05, 2018 6:35 pmThe -1 bolt does supersede to a NAS428H3A12 on the textron website.
How fortuitous! The very one I have. (Shameless plug...)
