Now and again I get a problem with my Delco generator... It stops working because of brush deposits on the commutator.
I clean it off and all is good again.
The brushes have quite a lot meat on them, but the contact end is now curved to the same profile of the commutator... Should these be re-profiled to form the 45deg angle of a new brush or do they just need replacing or is there something else going on?
Delco Generator brush wear
7698
- Name: TailWheelCharlie
- Aircraft Type: C120 - GAKVM
- Name: Ramp Rat
Re: Delco Generator brush wear
I know this may seem like a Dumb question. (Which I'm good at) But,
How do you "clean" the commutator?
And, BTW, John C is right.
Steve.
Steve.
America, Love it or Leave IT!
7698
I clean it up with scotchpad which works fine... However, I seem to be doing this quite frequently so think that there is some breakdown in the brush material... or perhaps its just normal, but I dont here the alternator users doing the same..
Is the commutator smooth? If not, you can smooth it with crocus cloth. Are the insulators sticking up between the segments? If so, they need to be cut back so they don't contact the brushes.
The biggest differences between the generator and alternator is the generator brushes carry the charging current whereas the alternator brushes only carry the exciter current and the generator brushes make and break between segments whereas the alternator brushes don't.
7698
Hi John,
Everything is pretty smooth... Had some 400 emery cloth around the commutator a while back.
Just wondering if the blast cooling tube plays any part in the material pickup problem? Its not connected to anything as there is no fitting on the baffles in my set up...
Could it be getting too hot and the brush material starting to get sticky??
You really should hook it up. The generator doesn't have a fan so, absent the blast tube, there is no airflow to cool it.
No, they're not made of anything that would melt at normal temperatures. Sticky material might be from the windings of the generator, in which case fix the blast tube sooner. Otherwise, look at the generator oil seal.Could it be getting too hot and the brush material starting to get sticky??
7698
Thanks all,
