ADS-B rebate
				8348
- Name: Paul D
Re: ADS-B rebate
I replaced my Narco 50 transponder with a Stratus ESG.  I had reserved the rebate around the end of March for a mid April install.  I picked up my 120 on 30 April and did my validation flight in the local class C, then submitted for the rebate.  I got an approval the next day and the check came in yesterday.  Surprisingly quick and painless process.
						- 6898
- Name: Jeff T
- Aircraft Type: 48 140 C90
							 Re: ADS-B rebate
						Re: ADS-B rebate
			I'm ADS-B compliant just in time for NO more rebates go figure. $500 i would just spend foolishly anyway
				8359
- Name: Tamer A
Re: ADS-B rebate
I was able to reserve one of the leftover rebates today. Got lucky I guess, I've failed the last 3 weeks. It makes you select which hardware you plan to use. I really want to use the tailbecon but I'm not sure I can wait any longer for it. I selected the GDL82, hopefully if the tailbecon comes out I can switch the selection on my rebate, we'll see. If not, I guess I'll just have to go with the GDL82, I already have a GTX327 so it's probably the best option anyways.
				8452
- Name: Larry B
Re: ADS-B rebate
A GDL82 and a 327 will make a great combination.
									Larry Bible
1966 Mooney M20F/J
1966 Mooney M20F/J
- Name: Rick F
- Aircraft Type: C-140 (sold)
Re: ADS-B rebate
I saw somewhere to check the FAA website for ADSB rebates on Wednesdays to see if any had become available due to errors on previous requests.
Do a little digging and you may get lucky.
				VIP529
- Name: Victor
- Occupation-Interests: Work on airplanes until the cows come home..........they're still out!
Re: ADS-B rebate
YES, keep checking, even though all the rebate slots are taken, not everyone ends up using their slot times for one reason or another. We had two customers "get a rebate" slot in the last 2 months or so.
- 8216
- Name: Sam Heiter
- Aircraft Type: CE-140
Re: ADS-B rebate
After a month of trying, I finally snagged one of the returned rebate slots this past Wednesday.  Should’ve bought a lottery ticket too
Re: ADS-B rebate
I just read in an article in AOPA Pilot that they release any expired, unused rebates at 1:00 PM Eastern time on Wednesdays.
				8359
- Name: Tamer A
Re: ADS-B rebate
That is correct, that's how I got mine, by hitting refresh on the browser enough times and getting lucky
 Although my request went through 2 min before the hour.
