Ethanol Free Gas
				4390
- Name: Franklin B
Ethanol Free Gas
Does anyone run ethanol free gas (87 octane)? If so, do you like it? Any pireps? Good / bad?
- Name: Mac Forbes
Re: Ethanol Free Gas
Yes, and have since the EAA STC was issued "many" years ago. I do use 100LL probably every other fill-up & often end up with a blend. With pure auto fuel I notice a difference in idle (...believe the STC mentions this) as well as on start-up in cold weather...plus the auto fuel stinks
 .  I've never realized any issues with abnormal wear of any kind.  My home field has no fuel so it's a nice "convenience" to be able add "car gas" when I need to.  I use ethanol-free fuel exclusively in my lawn mowers, too, incidentally. I never fuel the plane in the hangar and do my best to use a non-conductive funnel and to minimize the risk of static spark.  Mac
 .  I've never realized any issues with abnormal wear of any kind.  My home field has no fuel so it's a nice "convenience" to be able add "car gas" when I need to.  I use ethanol-free fuel exclusively in my lawn mowers, too, incidentally. I never fuel the plane in the hangar and do my best to use a non-conductive funnel and to minimize the risk of static spark.  Mac-
				4006
- Name: Mike Gourd
- Occupation-Interests: Electrical & Electronic Design & Troubleshooting
I run it frequently.  100LL has more  lead in it than Continental recommends. I probably average 75% mogas 25% 100LL. No issues to report. I have a
neoprene needle valve in my Stromberg carb and am aware of possible issues ( viewtopic.php?f=10&t=100 ) but have not experienced any problems, yet. I check my gas for ethanol, each time I buy it.
Mike Gourd,  Centredale Airport CDL8
				6298
- Name: Randy Thompson
Only, about, 6000 hours on auto gas so far.
- Name: Franklin B
Well, I tried some Ethanol free gas and it seems to run just fine at full and cruise power but stumbles quite a bit from idles speeds to power, even quit a few times. Like the idle mixture is too lean now. Do I have to adjust the carb to run this gas?
- Name: Mac Forbes
I've so carefully filed my (EAA) STC that I can't put my hands on it right now...but, as I recall, there's mention that the "conversion" to using auto fuel may prompt need for idle mixture adjustment. Mac
- Name: Mac Forbes
...found it (The EAA STC "Flight Manual Supplement" in the 140 right where it's supposed to be
 ):  "...If the engine tends to stop while gliding with a closed throttle, the idling mixture should be readjusted. If the engine stops when the throttle is opened suddenly, return the throttle to the closed position and open slowly or operate the primer for one or two strokes." I don't recall ever having any of those issues, even with 100% auto fuel but, again, I normally fly with a 100LL/ethanol-free auto fuel "mix"...been utilizing the STC since 1985.  Mac
