I know this was brought up before, but where can I find some? I have looked at Aircraft Spruce and Wicks.
Thanks, Bob Newell
						Source for elevator stop bolts
				4323
- Name: Bob Newell
- Aircraft Type: 1947 140 C85
- Name: Bob Newell
I am looking to replace the bolts with new ones. They are listed in the manual as part number
0431141 Bolt - Elevator Bell Crank Stop. I didn’t see them at Aircraft Spruce or Wicks.
Thanks, Bob Newell
Thanks, Bob Newell
				8175
- Name: Larry Lowenkron
- Aircraft Type: Cessna 140A
Re: Source for elevator stop bolts
Winner Aviation in Niles, OH has 0431141-1.  I found them doing a part number search on Controller.com.
Not sure what the dash 1 is, but might be worth a call to them.
https://www.controller.com/parts/aircra ... pst=starts
Larry Lowenkron
C140A N5641C
Larry Lowenkron
C140A N5641C
Are they 10-32 bolts? If so, I have an NAS428 stop bolt that works for the ailerons and should work there, too, except you may have to shorten them. They are 1-1/4" long and threaded over the whole length of the bolt.
- Name: Bob Newell
Thanks Larry and John, I haven’t had time to check on them yet. I should be able to look into it next week.
Bob Newell
						Bob Newell
I checked the parts catalog and they screw into a 10-32 nut, so the ones I have should work, unless the heads drilled for safety wire.
- Name: Jeff Hettling
- Aircraft Type: C120
- Occupation-Interests: Aircraft Technician
They’re made from an AN3H-11A bolt with threads cut most of the way up the shank.  The -1 is the same except made from an AN3H-15A.  There is also a -2 and a -4, same but even longer AN bolts.
Jeff
						Jeff
Stop bolts have no raised markings on the head. Also, if Cessna is making them from AN hardware, then I'm guessing they're re-plating them after.
I'm sure they were, have to justify them being so expensive somehow!
The -1 bolt does supersede to a NAS428H3A12 on the textron website.
Jeff
Jeff
How fortuitous! The very one I have. (Shameless plug...)
