O200A Cruise RPM?
8452
Occupation-Interests: Retired Automation Engineer, Nothing to do and all day to do it.
O200A Cruise RPM?
Post by 8452 »
I typically cruised my old, tired engine at 2450. Can I bump that up some with my fresh, strong engine?
What do you cruise at?
Larry Bible
1966 Mooney M20F/J
8452
Re: O200A Cruise RPM?
Post by 8452 »
Come on folks! You can share your favorite cruise RPM.
Larry Bible
1966 Mooney M20F/J
8424
Name: Steve A H
Aircraft Type: 1950 C140A
Post by 8424 »
Hi Larry.
My O-200 powered 140A isn't flying yet (motor is still on the 150, but I do have the STC!) , but I had a 150F that I cruised at 2400-2450 and was planning on the same with the 140.
Hope some of the O-200 flyers will join in.
Steve H
2356
Post by 2356 »
I use 2550. I believe this is 75% power.
Post by 6298 »
I cruise at about 2550 RPM.
8452
Post by 8452 »
Thanks a bunch guys!
Larry Bible
1966 Mooney M20F/J
Now if you're flying power line patrol, and want to increase your time on station, I use 2200-2250. When I want to go someplace 2450, but that's me. Others report higher power settings. Big thing here is the faster that crankshaft turns the more fuel you're going to burn. All boils down to what you are trying to do. Just my 2 cents.
Aircraft Type: Cessna 120
Post by 7896 »
2450 rpm for me too. Results in ~105-110 mph on the airspeed indicator.
Michael Haas
'46 120 - N76219
Home Base: W96 (Quinton, VA)
7392
Post by 7392 »
Just out of curiosity, what RPM do you guys set with an 85-12F with a 69.5X49 prop?
I vary between 2300 to 2500......depends on if I want to get there in an hour or an hour
and 5 minutes.
Larry Surratt
1946 140
N89011
serial#8015
26R/JACKSON COUNTY TEXAS
VIP529
Occupation-Interests: Work on airplanes until the cows come home..........they're still out!
Post by VIP529 »
I'm a little late to the party,
I cruise at 2500 consistently. That being said, some engines are smoother at one RPM or another. My engine likes the 2500-2600 RPM range. Below 2450 it is noticeably rougher. No scientific data, but I've always felt that a smooth running engine is probably a happy engine, so I leave the RPM's where they are the smoothest.
I had a Mooney (yeah......I know..........somebody's gonna kick in with ..........."I'm sorry") for almost 20 years. It also had very defined "smooth" Rpms' even with the constant speed prop and much more availability to move around RPM and manifold pressure, I typically cruised at the smoothest RPM.
