Trim actuator
Occupation-Interests: Machinist
Trim actuator
Post by 8232 »
I was looking for some information on the trim actuator. The one on my plane has developed some play in the actuator. Finding a original one in good shape might be pretty hard. I was seeing if a actuator out of a Cessna 150 might be an easy swap. They look similar in the 120/140 parts catalog but different than the one in my 140. Thanks for any help.
1946 140 10439
David
Re: Trim actuator
In 35 years of owning a 140 that's one of the few items that I haven't had to deal with...yet :roll: . There'll no doubt be a dependable answer here, but my initial guess is that the 150 part may be a fit (...sorry I can't be more "dependable" than that). The 140 #0310293-10 seems to be superseded by Cessna #1260074-1 and that appears to be called out for the Cessna 150 also. From Yingling's website catalogue:
SKU: 1260074-1
This part replaces:
0310293
0310293-10
0310293-11
0310293-13
0310293-14
0310293-2
0310293-1
That said, I'm "assuming" that they're interchangeable...but, again, I'm confident that there'll be a more dependable answer coming along here shortly.
Mac
Re: Trim actuator
I installed the #1260074-1 unit after my old actuator showed way too much play and I had some flutter. It was a drop in replacement. That said, the movement on the trim wheel was much more sensitive and it took less 'turn' to achieve the same response from the old unit.
columbiaairmotiveactuators5-13-09 004.jpg (89.43 KiB) Viewed 6005 times
Trim Tab Max Limits.pdf
(19.83 KiB) Downloaded 742 times
Trim Tab Allowable free play.docx
(13.38 KiB) Downloaded 777 times
Re: Trim actuator
^There's that dependable answer! Thanks, Dave!! And, FWIW, I did see this one on Ebay (Wow -- prices for actuators are all over the place, with most being in a HIGH place! :shock: ):
Cessna 120 Cessna 140 elevator tab actuator PN 031093-10
$110.00
or Best Offer
+$7.85 shipping
Guaranteed by Fri, Aug. 16
Mac
Re: Trim actuator
Post by 5115 »
I thought at some point we had a thread with pictures of a member that had opened one and restored the over-spec pieces.
I may have those pictures on my computer at home. That will have to wait for another week before I can get them on this thread.
Martin Tanguay
Re: Trim actuator
Beat you to it...
Re: Trim actuator
I found the old thread. I'll restore it in the next few days and link to it here.
Re: Trim actuator
Post by 5115 »
6597 wrote: Sat Aug 10, 2019 8:45 pmBeat you to it...
:lol: :lol: :lol:
You are fast David
Martin Tanguay
8232
Re: Trim actuator
Post by 8232 »
Thanks for the information.
David
Re: Trim actuator
6643 wrote: Sat Aug 10, 2019 8:58 pm I found the old thread. I'll restore it in the next few days and link to it here.
viewtopic.php?f=14&t=775
