Push To Talk button location
Name: John von Linsowe
Aircraft Type: 48 C-140
Occupation-Interests: CFI
Post by 5806 »
Where is your PTT button located? Photos?
I have used a Telex PTT that plugs in series with the headphone mic for years but am considering an installed push button on the new radio install.
John
Re: Push To Talk button location
I put one in the plastic hub of the pretzel yoke for a friend once. Sorry, no pictures...
Aircraft Type: 48 140 C90
Post by 6898 »
Send your email to colorfastinc@sbcglobal.net and i'll send some photos
Post by 6298 »
I put mine just to the right of the throttle. I can push it with my hand on the throttle. Been that way for years..
I recently flew a friend's 140 with a momentary PTT toggle left of throttle (similar to Randy) -- surprised at how easy & natural it was to use with hand on the throttle (where it usually is?). Mac
Aircraft Type: Cessna 120
Post by 7896 »
Simple solution. Works well for me.
PPT on Yoke.jpg (70.15 KiB) Viewed 12545 times
Michael Haas
'46 120 - N76219
Home Base: W96 (Quinton, VA)
Aircraft Type: C140A
Post by 8474 »
Will tidy this up a bit when the airplane gets its new interior, but for now it works well.
Aircraft Type: 46 140 0-200
Post by 6352 »
Mine are on the yoke, as above. But they were that way when I bought the plane. If I were to do it myself I would put it on the panel somewhere. Simple, no wires in cockpit. I used to rent a 150 that had that arrangement and adjusted to it quickly. KISS.
Mike Rabe
C140
KDVT
2066 wrote: Wed Aug 14, 2019 8:13 am I recently flew a friend's 140 with a momentary PTT toggle left of throttle (similar to Randy) -- surprised at how easy & natural it was to use with hand on the throttle (where it usually is?). Mac
Mac & Randy,
can you post pictures of your ptt? I'd like to get a visual on it.
7836
Aircraft Type: C120
Occupation-Interests: Airport Manager
Saline County Regional Airport
Post by 7836 »
8474 wrote: Wed Aug 14, 2019 12:42 pm Will tidy this up a bit when the airplane gets its new interior, but for now it works well.
Mine is similar to this except flat metal screwed to back of yoke not wrapped around.
