Hello all. I have a delco remy generator on my 0200. And need a voltage regulator. Thanking all.
Pat
Wtb voltage regulator
8263
- Name: Patrick G
- Aircraft Type: 1946-140
- Occupation-Interests: Journeyman wireman
Re: Wtb voltage regulator
Let us know what the amp rating is on your generator as it has to match the regulator.
- Name: Tamer A
If you're sure you want to keep the generator and not upgrade to an alternator, I would recommend the zeftronics, it's a little more expensive, but is a bit more reliable.
