motorized tug
7103
motorized tug
Does any one use or know where to get a motorized tug for a C140
- 6898
- Name: Jeff T
- Aircraft Type: 48 140 C90
Re: motorized tug
Lots out there most small powered ones start around $2800 ouch. Look for used in your area?
Re: motorized tug
I used to use a lawn tractor and a Wag Aero tailwheel tow bar. Cut the "T" off the handle and welded a ring on and pined it to a Bracket I made on the front of the tractor.
You cam probably pick up a tractor with a bum mower for a couple hundred bucks.
Re: motorized tug
I have a Minimax Tug and it works great. It is not the cheapest thing, but very easy to use.
- hotrodmac
- Name: Lance B
Re: motorized tug
Thinking about building one of these. The cost of the commercial ones is waaay to high!!
http://www.vansairforce.com/community/s ... p?t=169376
‘53 C170B w/Avcon O-360
120-140 Assoc. NC Rep.
8244
- Name: Rick C
- Aircraft Type: 120
Re: motorized tug
Would a pull handle installed work for you. It really works nice makes moving pretty easy.
