Does anyone know if you can buy new fuel caps for a 1948 c140
wichita140
Need to replace my fuel caps on my 1948 Cessna 140. Mine have two vent holes in the top of each is this right???
- Name: Randy Thompson
Re: Does anyone know if you can buy new fuel caps for a 1948 c140
It is right! I bought some a while back. I’ll see if I can find the part number in the next day or so.
These fit nicely. I haven’t drilled another hole yet, but. it will be easy. Part number is 05-01058 from Aircraft Spruce. Picture is too large..
Here's the picture:
- VIP620
- Name: ken tengesdal
- Aircraft Type: 120
https://www.greenpartstore.com/John-Dee ... 20911.html if yours are vented, this one works
- Aircraft Type: C-140 (sold)
You need to read this posting in Neal Wright Technical Articles:
Mis-using gas caps on 140s that are meant for 140/120 planes
It will explain venting on each type of airplane and what type of gas cap you should use for each.
