Hello all. Could someone please tell me the glide ratio for a cessna 140? Thank you all.
Pat
Glide ratio
8263
- Name: Patrick G
- Aircraft Type: 1946-140
- Occupation-Interests: Journeyman wireman
- Name: John von Linsowe
- Aircraft Type: 48 C-140
- Occupation-Interests: CFI
Re: Glide ratio
I have heard... a little better than 7:1.
Semi-related to the subject, it varies under different weight loadings but in my airplane about 1600 rpm the "glide ratio" is similar to a low performance sailplane. Circling in thermals can actually produce a climb on a good day.
John
8482
- Name: Samuel G
- Aircraft Type: '46 140
Re: Glide ratio
I'm guessing you are wanting this for Foreflight? I use 7. I hope that is a conservative number if I ever needed to rely on it. But yeah, loading and environmental factors can affect that number as previously stated.
- Rob Swanland
- Name: Rob
- Aircraft Type: C-140A
- Occupation-Interests: Website & Forum Administrator
Re: Glide ratio
Yes, 7:1 is very conservative but better to be on the safe side. Lightly loaded you should be able to achieve 10:1, maybe more if the prop is not windmilling.
8263
- Name: Patrick G
Re: Glide ratio
Yes it is for foreflight. 7:1 it is. Thanks for the response guys
Pat
Pat
