150 Exhaust STC
8482
Aircraft Type: '46 140
Re: 150 Exhaust STC
Post by 8482 »
6643 wrote: Tue Oct 15, 2019 7:16 pm
8482 wrote: Tue Oct 15, 2019 11:29 am This will fit on my O-200-A right?
All C-series Continentals, including the O200, and I believe, all A-series Continentals, have the same exhaust port spacing.
Thanks! That's what I thought. I am going order the exhaust then. I hate flying around in the winter with the cabin heat on thinking that I'm going to pass out.
Re: 150 Exhaust STC
FWIW IIRC Years ago there was a "stick-on" that one could place on the instrument panel that would change color in the event that the level of carbon monoxide was increasing to a dangerous level. Might check Spruce to see if still available. 2c
Re: 150 Exhaust STC
Re: 150 Exhaust STC
Post by 8322 »
5806 wrote: Wed Oct 16, 2019 9:53 am
8322 wrote: Tue Oct 01, 2019 10:18 am Not sure how it works, if theirs covers this or not, but when mine was done in 1980 they used the 150 setup that pulls heat off both sides... I know our gals have a reputation for low heat output... Mine with that set-up will cook you out...
Hello Raymond,
Curious if the carb heat is shared with cabin heat on one side?
John, I will have to look to refresh myself on how it goes. Its going in for annual in the next week or two, so I'll see if I can get come cowl off pics
Ray
8322
Re: 150 Exhaust STC
Post by 8322 »
Here is how my setup was done, I have plenty of heat!
Hope this can help someone else doing this...
