Originally Posted on Thu Aug 25, 2005 3:12 pm
The original copper 1/8th inch tubing used to transfer the pressure from the engine fitting to the firewall will work harden because of vibration. An owner can replace it by making a new one or the Neoprene hose from a Cessna 150 can be substituted if available. If not, a new hose can be fabricated with the instructions in the article or from an authorized hose maker.
Neal
Oil Pressure Hose Replacement for the Copper Tubing
101
- Name: Neal Wright
- oil_press_hose__05_.pdf
- A Neoprene hose replacement for the original copper oil pressure line forward of the firewall.
- (106.2 KiB) Downloaded 4586 times
