Prop pitch
hughrawls
- Name: Hugh Rawls
- Occupation-Interests: Pilot and cfiime, a&p
Prop pitch
My 140 with O200 has a 69-48 prop (climb). I need a recommendation for a cruise pitch. Engine will overspeed in cruise if I am not careful.
8451
- Name: Daniel
Re: Prop pitch
I was under the impression that over speeding in cruise at full throttle was normal for climb props - it’s one of the trade offs that comes with being able to make more RPM and thus power at climb airspeeds.
- Name: Ray Hunter
Re: Prop pitch
Climb props will overspeed if you don't reduce throttle setting at level off. If you're in a hurry and want a few knots more in cruise, a cruise prop is your choice. If you want better performance on takeoff and climb, keep the prop you have.
Re: Prop pitch
Check your tach. Is it accurate.
A 69/48 should just nicely make rated RPM, straight and level with full throttle at 1000 feet.
Re: Prop pitch
I would expect a 69-48 to easily exceed redline in level flight. Remember, it's on an O-200, not a C-85. -50 or -52 is probably what you want if you want to cruise at high throttle settings.
Re: Prop pitch
Can a 6948 be legally installed on a Cessna 140/120/140A with the 0-200 conversion? At one time the only approved propeller was the 6950. Paperwork in my 0-200 installation specifically calls for only the 6950. Personally I wouldn't kick a 6948 out of the house. On more than one occasion I would have liked to had a 6948 installed especially during 100+ degree weather while doing patrol work. Can someone shed some light on this subject and tell us if a 6948 is legal on an 0-200 powered 140/120/140A?
Re: Prop pitch
Ask Randy. I thought he was working on having a static range approved rather than a specific pitch, although I may be thinking of my own problem, having a 6948 as the only approved prop for an Ercoupe/O-200.
- Name: Randy Thompson
Re: Prop pitch
If you have the current version of my STC, it allows pitches from 48 to 54. I fly a McCauley 69-48, 1A101. Maximum static RPM is 2600. I seldom exceed the red line of 2750 RPM. I think the prop on Hughs is a Sensenich. The static rpm limitations are narrower than the McCauley, on them. The McCauley 1A100 pitch range is 50-54.
