Leather upholstery
5469
- Name: Horacio Berardone
Leather upholstery
Hello,
I will do a new upholstery for my C140.
I got the headliner material from Airtex interiors. It is a certified material.
I want to make the seat with natural leather, here is relatively cheap and has superb quality.
The question is to make sure that natural leather is legally and technically correct.
Is any paperwork needed for this work ?
Thanks very much,
Kind regards,
Horacio
Thanks very much,
Kind regards,
Horacio
Horacio Berardone Bouhébent
LV-NGL 1946 C140 SN 10.260.
- Name: Blaine F
- Aircraft Type: C140A
Re: Leather upholstery
I'm currently having my seats recovered with leather. This leather was a gift from someone who worked at a major airline here in Canada who used it on their passenger seats. I did find a sticker on it with the companies name so I do know it was used on aircraft, but no what you might call approval number. I'm not worried about using it as you can order leather seat covers from Airtex and I doubt their cows are any more flame retardant that yours
8244
- Name: Rick C
- Aircraft Type: 120
My current airplane has leather interior with all the proper paperwork done by the upholstery shop at my home airport A previous airplane , I purchased leather from an advertisement in trade a plane and had a piece of each leather sent out and burn tested as required. I don’t remember how much the cost was or where it was sent but I would recommend doing what is required so your not throwing your money or leather away
5469
Thanks very much for both answers,
Kind regards,
Horacio
Kind regards,
Horacio
Just FYI, when these planes were certified (CAR-4a) there were no regulations on interior materials, so, strict adherence to the regulations doesn't mean anything in this context. This is not to say that you shouldn't concern yourself with using fire retardant materials, just that there is no standard to which you must comply.
- Name: Rick C
Thanks John I wasn’t aware of that , really appreciate all of your excellent and helpful advice.
An interesting anecdote:
The Ercoupe 415C is certified under CAR 4a. The 415D is certified under CAR 3. CAR 3 does incorporate a flammability standard. Both TCDS's incorporate procedure to convert from the model C to the model D. (There is an increase in gross weight.) Part of the conversion process is to install a "No Smoking" placard. Why? No ash tray...
From CAR 3:
3.388 Fire precautions—(a) Cabin interiors. Only materials which are flash resistant shall be used. In compartments where smoking is to be permitted, the materials of the cabin lining, floors, upholstery, and furnishings shall be flame-resistant. Such compartments shall be equipped with an adequate number of self contained ash trays. All other compartments shall be placarded against smoking.
(Definitions: (d) Flash-resistant. "Flash-resistant" material means material which will not burn violently when ignited.)
There is no equivalent text in CAR 4a. Evidently, the materials used in the interior of the 415C must have been at least "flash resistant".
From CAR 3:
- Name: Ramp Rat
- Occupation-Interests: Semi-Retired A&P
What about Inspecta-Shield? I've used it on fabric but, never leather.
Just a thought.
JMHO, Steve
Just a thought.
JMHO, Steve
America, Love it or Leave IT!
atypicalguy
- Name: Karl
That's helpful. I wonder if I can get rid of the wire spring back from the bench seat somehow and use some sort of aramid or nomex webbing instead fastened to the frame with some foam over it. Or just nomex cloth. I think mine has the original horse hair in it still.6643 wrote: ↑Wed Nov 20, 2019 8:03 pm Just FYI, when these planes were certified (CAR-4a) there were no regulations on interior materials, so, strict adherence to the regulations doesn't mean anything in this context. This is not to say that you shouldn't concern yourself with using fire retardant materials, just that there is no standard to which you must comply.
atypicalguy
- Name: Karl
My placard says "If you must smoke, please step outside". It was there when I bought the plane.6643 wrote: ↑Thu Nov 21, 2019 7:48 am An interesting anecdote:
From CAR 3:
