Static RPM data
Name: John von Linsowe
Aircraft Type: 48 C-140
Occupation-Interests: CFI
Static RPM data
Post by 5806 »
I am looking for 'real' data that anyone has showing what their static RPM is with a C-90 and a 1B90/CM7151 prop. I will be checking with a digital tach soon and would like comparison data.
John
Re: Static RPM data
Post by 6298 »
The Type Certificate data sheet for the C-90 with a 1B90 CM states not over 2350, not under 2000 for landplane.
Re: Static RPM data
Sort apples to oranges, but I get 2050 - 2100 RPM with a 7152 which is really a 7052.
8252
Re: Static RPM data
Post by 8252 »
i currently have 2200 with the old round tipped 50", 2050 with modern square tipped pitched to 54"
8279
Aircraft Type: C140A
Occupation-Interests: Semi Retired
Re: Static RPM data
Post by 8279 »
I have a 140A C90-14F and a McCauley 1B90CM 7151 and I’m getting 2160 static RPM...
