Tailbeacon Installation
Re: Tailbeacon Installation
Post by 8170 »
That's why I love being my own IA :)
6930
Post by 6930 »
Well, looks like I found a couple of local shops that will install it for me. :D
Hoping to get it done next week and will post the final results.
Mike
Good news, Mike! Thanks for the update -- hopefully it'll end up being as simple as it should be. Mac
If you get desperate, I know a place in Middletown OH that will do it for you.
6930
Post by 6930 »
2066 wrote: ↑Mon Nov 25, 2019 8:12 pm Good news, Mike! Thanks for the update -- hopefully it'll end up being as simple as it should be. Mac
Thanks Mac. I think it should go smoothly. I was talking to the FBO this morning and unless they surprise me with unforeseen BS, I should be okay. They actually sell tailbeacons and seem to be happy to install mine for me.
Mike
6930
Post by 6930 »
6643 wrote: ↑Mon Nov 25, 2019 9:02 pm If you get desperate, I know a place in Middletown OH that will do it for you.
Thanks John. At this point it looks like I have some good local options. I was actually thinking of going out of the area to get it done and I appreciate your offering to get me info on the Ohio people.
I should have it finished within the next couple of weeks and will post the final outcome.
Mike
8482
Aircraft Type: '46 140
Post by 8482 »
Hello All,
I only have a single lead going to my light on the rudder. Curious if anyone else encountered this? We will need to add a ground. Any clever solutions? Or do I just need to have the wiring redone.
-Sam
8359
Post by 8359 »
Sam,
Mine only had a single power wire as well. The body of the tailbeacon provides the ground to the airframe in the same way the current tail light works.
I decided not to run a ground wire, however at some point when the aircraft is down for an extended period I plan to run ground wire and hook it up.
Hope this helps.
The original wiring was a single conductor to the tail light. In my opinion, since the rudder is not bonded to the airframe, you really ought to run a ground wire from the Tail Beacon to the airframe. The tail beacon detects transponder traffic through the power wiring, and without a good ground that might be compromised under some conditions.
Post by 6277 »
I had the same issue, no good ground wire. You could "bond" the rudder to the airframe in some way with a flexible bonding cable. I ran a separate ground wire. Had to take the rudder off to get the wire through the various bulk-heads. Used an old fishing rod to thread the gnd wire through to where I could reach it.
