Thanks Chris! Do you have a doubler or is it just reinforced with washers or...? Did you just do this with a log entry or a 337 or...?
Larry
shoulder harness
8175
- Name: Larry Lowenkron
- Aircraft Type: Cessna 140A
- Name: Christopher B
- Aircraft Type: C120
- Occupation-Interests: USAF
Re: shoulder harness
It was done by 337 about 30 yrs ago. I don’t believe there is a doubler...I’ll find the paperwork and send you a picture
8175
Thanks, I really appreciate it.
Larry
llowenkron at yahoo
Larry
llowenkron at yahoo
1307
- Name: Chuck
- Location: KVAY, South Jersey Regional Airport, New Jersey
- Occupation-Interests: Retired. Comm ASMEL, Istrument, CFI, CFII, MEI, A&P/IA, Flight Engineer.
Having been in a crash in an older B55 Baron in August, 2012, that did not have shoulder harnesses installed, I can attest to the need for them. With a cracked and dented skull, and a broken neck from my head hitting the instrument panel, I will NEVER occupy a seat in a GA plane that does not have them installed. The Baron pilot died from severe head trauma 12 hours after the crash. My 140 has had a 5 point Hooker Harness installed for both seats, for many years. Works great. Not a fan of a single, diagonal strap without an airbag.
5765
- Name: Greg L
- Aircraft Type: 1948 C140/C-90
- Occupation-Interests: retired
I’m a big fan of the Hooker Harness. Secure 4-point design that will really hold you securely when needed. Not overly restrictive in flight.
1948 Cessna 140 N3693V
Serial Number 14969
Based at KCMA
Serial Number 14969
Based at KCMA
