New guy pattern speeds flaps
cubrath
Post by cubrath »
New guy here. I just purchased a 140 to teach my kids to fly in and due to weather I haven’t been able to pick it up yet! I own a 195 and I just couldn’t bear to have them learn in a nose dragger. It will also make for a good time builder and transition airplane to the 195.
I have a few questions that I couldn’t find searching the forum. Can anyone give me an overview of a standard pattern. Speeds and flap setting?? It’s a 1948 140 w/90hp.
Takeoff-Normal flap setting?
Vy-70 I think I found
Downwind speed?
Base speed?
Final speed?
When and how much flaps for Normal and cross wind landings.
I’ll get a checkout but would like to know what the experts think!!!
Mike
Re: New guy pattern speeds flaps
Well, you'll get a lot of opinions, no doubt. There are (AFAIK) no manufacturer supplied numbers.
None. Full flaps at about 40 mph if you want to do a soft field takeoff. Just don't forget to retract them when you get a little faster.
Probably pretty close; I use 65.
Downwind speed?
About 70
Base speed?
About 65
Final speed?
About 60; 55 for short fields.
You will find the flaps don't do much. They're good for lowering the nose somewhat; they act like tiny speed brakes. Good training aids for when you get a plane with "real" flaps. That said, I don't use them until I'm on final and then I use them all, or none. For training, no reason not to use one notch midfield down wind and another on base.
6352
Aircraft Type: 46 140 0-200
Post by 6352 »
What John said. And just for clarity, mph, not knots. Good for training. In reality, I typically fly somewhat faster on downwind and base and slow to 60 mph over numbers for 3 pt, maybe 60-65 for wheel landings. Just so I don’t make life too difficult for the controllers at our busy airfield fill of Archers flying 3 mile finals.
Mike Rabe
C140
KDVT
Post by 6277 »
Here's a site that might be of use to you.
https://ad7zj.net/wiki/images/1/19/Oper ... 20_140.pdf
cubrath
Post by cubrath »
Thanks guys! A healthy forum makes ownership so much more enjoyable!!
Post by 6277 »
Here's another document that you might find useful. I downloaded it from this site years ago. It's no longer available to download here.
AFM.pdf
(329.38 KiB) Downloaded 920 times
6277 wrote: Sun Feb 09, 2020 1:28 pm Here's another document that you might find useful. I downloaded it from this site years ago. It's no longer available to download here.
There's a copy of that document along with a lot of other helpful information in the Cessna 120/140 Reference Manual that's sold in the Association Store. Good manual to have if you're new to the aircraft.
