Trying to remove LH fuel gauge to get it overhauled and one screw won't budge. All were tight but one won't budge. Tying to avoid drilling it out. Any thoughts?
Alexis Lake
						140 fuel gauge attach screws
				7130
- Name: Alexis
- Occupation-Interests: Licensed Clinical Social Worker
 A&P IA
Re: 140 fuel gauge attach screws
PB Blaster or Kroil
More leverage (Ratchet and socket driver)
Heat (Caution! Fire hazard!)
Shock it with a hammer
Shock it with an impact driver (be careful not to damage anything!)
- Name: Larry Lowenkron
- Aircraft Type: Cessna 140A
An old A&P told me to try and tighten (yes, tighten!) it for just a little.  Tried it numerous times now, and I'll be darned if it didn't work!!
Copied the following from some old post I found at another site.
" Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating oil ..... Average load
None ............ ......... 516 pounds
WD-40 ............ ...... 238 pounds
PB Blaster ............ ..214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix... 53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price."
Just be careful where you use it, 'cause the acetone may dissolve plastics.
the acetone may will dissolve plastics.
- Name: Alexis
 A&P IA
Thanks guys. I've tried all but trying to tighten it. I'll try that on Sunday!
				7130
- Name: Alexis
 A&P IA
Got it out. Enlarged and squared the screw slot, got a larger screwdriver, with a wrench on the screwdrive, it finally came out.
