O-200 STC
aus140
Occupation-Interests: Helicopter maintenance
O-200 STC
Post by aus140 »
Good morning ,I am currently restoring a 1946 Cessna 140 which had a O-200 installed in 1974 under STC SA267SW ,does anyone have a copy of this STC as I would like to keep this engine any info would be helpful
Re: O-200 STC
Post by 6298 »
I hold STC547EA. It was created with the S&S Pipeline Patrol STC SA627SW, since it was expired. The 120, 140 and 140A were added as well as some other propeller choices.
Re: O-200 STC
OP-
If the engine was installed under that STC, why would you not be able to keep it?
Re: O-200 STC
Post by 6298 »
6643 wrote: ↑Sun Mar 15, 2020 9:07 am OP-
The pipeline patrol STC was pretty narrow in scope. I’m still looking for the details. Hopefully someone has a copy of it for aus140. It looks like it was incorporated into my STC in 1967.
aus140
Re: O-200 STC
Post by aus140 »
Thanks for the replies , I require the stc for the flight manual supplement, install and maintenance data
Re: O-200 STC
Post by 6298 »
aus140 wrote: ↑Mon Mar 16, 2020 2:46 am Thanks for the replies , I require the stc for the flight manual supplement, install and maintenance data
I sent you a PM with my contact information. I found most of what you are looking for.
bus-driver
Re: O-200 STC
Post by bus-driver »
Is there a way to get the technical information on the SA267SW STC (drawings etc.)? I'm currently considering to buy a C140 with that STC in Germany and would need that information to be able to put the plane on the German register.
Best regards from Germany
Johannes
Re: O-200 STC
Try contacting Randy (6298) through the Private Message system. Just click on his user id and select "Send Private Message".
If that doesn't work, look up the STC in the FAA STC database and get his contact info from there.
Re: O-200 STC
I’ll give Randy a heads up on this post. I don’t think he visits the site as much as he used to.
