AUS140 1946 140
- Name: Darren
- Occupation-Interests: Helicopter maintenance
AUS140 1946 140
As I have just joined and am asking for help ,I thought I would post a couple pics ,this started out as a good idea and cheap, that was 2 years ago ,as with any 70 year old aircraft there are always issues, some I knew about others were surprises ,so far I have cleaned out the bitumen and asbestos coating behind the instrument panel, replaced forward landing gear bulkhead ,roof ,rear carry through spar and rear fuselage skin painted the fuselage and a thousand other things and am finally getting closer to the end
- IMG_20180922_170511.jpg (483.16 KiB) Viewed 41037 times
- As purchased
- IMG_20180326_164433.jpg (234.3 KiB) Viewed 41037 times
- Name: Randy Thompson
Re: AUS140 1946 140
I sent you a Private Message about the Pipeline STC info. Nice work your doing!
- Name: Darren
Re: AUS140 1946 140
Before and after
- R3.jpg (41.58 KiB) Viewed 41007 times
- R2.jpg (58.26 KiB) Viewed 41007 times
