Approved Flight Manual
gryph0n
Name: Steve S British Columbia Repr
Aircraft Type: 1948 C-140 O200
Post by gryph0n »
Hello All,
The C 140 Type Certificate Data Sheet requires this piece of interior equipment:
403. CAA Approved Airplane Flight Manual (optional nomenclature:
"Approved Operating Limitations") and pertinent revisions applicable to the particular model and serial
number.
I was previously under the impression that the 120/140 Operations Manual fulfilled this requirement, but the Ops Manual makes reference to “the CAA Approved Airplane Flight Manual”, so it can’t be it.
Where does one find said Manual?
Thanks, Steve S
2356
Re: Approved Flight Manual
Post by 2356 »
The original was a two page type written document that had specific data for each aircraft. Weight and balance, optional installed equipment. Hopefully it’s in your paperwork.
It's Form ACA-309. It should be in your permanent aircraft records. If not, order the FAA CD for your plane. It should be in there. I'm attaching mine, so you can see what it looks like.
I'm guessing there is a large percentage of the fleet that is not carrying this document... Mine's not up to date: I have a C90 now.
ACA-309.pdf
(273.23 KiB) Downloaded 1162 times
gryph0n
Post by gryph0n »
Helpful, thanks John and George.
Post by 6277 »
Here's what I thought
AFM.pdf
(329.38 KiB) Downloaded 1029 times
was the Approved Flight Manual.
Aircraft Type: 1946 C120
Post by 8233 »
6277 wrote: Sun Mar 29, 2020 11:39 am Here's what I thoughtAFM.pdf was the Approved Flight Manual.
Ray,
I believe you are correct. See attached Service Letter from the library that states CAA Form 309 is no longer needed in favor of what you posted.
Airplace-flight-manual.pdf
(37.97 KiB) Downloaded 966 times
Aircraft Type: C140A
Post by 8474 »
Is there one of these available for the A model?
regular122
Aircraft Type: 1948 C140 C90
Post by regular122 »
Is there one for a 140 with a Continental 90?
Steve
regular122 wrote: Tue Apr 07, 2020 10:31 pm Is there one for a 140 with a Continental 90?
Mine is for a C85 with a few things crossed out and the correct values penciled in.
8474 wrote: Mon Mar 30, 2020 8:18 am
Yes, do you have a copy of the Association Maintenance Manual? There's a copy in that book that can be used.
