140A Door stop
8474
Aircraft Type: C140A
Re: 140A Door stop
Post by 8474 »
Thanks for the link, now thats a reasonable price.
Re: 140A Door stop
Best I recall, the Sky Catch design fits and functions well for the 120-140 (vs. 140A) with the receiver on bottom of door and "catch" on the strut(?). It may be adaptable to the 140A, but would probably still require a serviceable catch at the wing attach(?). A great option if it works, in any event. Mac
Occupation-Interests: Continued Operational Safety Program Manager
Re: 140A Door stop
Post by 8029 »
Looks like the "Sky Catch" must be what I have on my 140. Works well.
Rob Ramey
1947 C140
steve140
Aircraft Type: Cessna 140
Occupation-Interests: Barely employed Dash 8 Pilot
Re: 140A Door stop
Post by steve140 »
Yep those are the ones I have on my 140. My dad has them on his 150 as well. Work great and won't wear out in a few years.... 8-)
steve140
Re: 140A Door stop
Post by steve140 »
2066 wrote: ↑Fri Apr 17, 2020 9:45 am Best I recall, the Sky Catch design fits and functions well for the 120-140 (vs. 140A) with the receiver on bottom of door and "catch" on the strut(?). It may be adaptable to the 140A, but would probably still require a serviceable catch at the wing attach(?). A great option if it works, in any event. Mac
On a 140A you could probably mount it at the top of the door and have a tab on the wing like the 150's have.....
Re: 140A Door stop
steve140 wrote: ↑Fri Apr 17, 2020 11:11 pm
Yep. Although I'm thinking that it's the tab on the wing that's broken on the OP's 140A and that's what costs so much...even the "serviceable used" are pricey. Mac
8474
Re: 140A Door stop
Post by 8474 »
2066 wrote: ↑Sat Apr 18, 2020 11:10 am
Yes, thats the problem, the part on the wing is broken. I was leery about drilling those rivets out that hold it on as I was thinking that was the bottom of the fuel tank, like a wet wing would be, but the tanks are separate correct? Do the tanks sit on stringers of some sort? Meaning is there a gap between the bottom of the wing skin and the fuel tank?
Re: 140A Door stop
Blaine wrote: "...is there a gap between the bottom of the wing skin and the fuel tank?"
I can't answer, 'though would "assume" so -- someone will come along who definitely knows...good to be cautious as drilling into the tank would ruin your whole day. I did have to drill in the top of my 140 wing (over tank) a while back to enable a pulled rivet where a fabric clip had let go & I was warned to limit the depth for drilling the hole. No doubt someone who's been into the "A" wing bottom will be along...shortly. It's a bummer that you're having to go through this. Mac
8474
Re: 140A Door stop
Post by 8474 »
Thanks Mac...yes, at least it is the pilots door so I can hold onto it and be careful opening, but I want to fix it.
Re: 140A Door stop
Any pilot who can handle a chopper can easily hang on to a flapping door! 8-) Seriously, there's gotta be a simple (...relatively) way to R & R as well as a reasonably priced replacement out there. There'll be more help here at some point, & we'll keep an eye out for the part. Mac
