Aluminum wingtip
Re: Aluminum wingtip damage
Post by V529 »
I see on top of your wings you have the 3 signature bumps on the aft spar of your metalized wings. I'm certain that means those wings were metalized by Farley Vincent He was heavily involved in 120/140 restoration work and mods.(eons ago) I can guarantee you that those wrinkles were not there when he covered the wings. He did seamless work.
Is the wrinkle because of your wing tip bump or was it there prior........I don't know.
I can say this. A. wrinkled skin means something is bent underneath. B. Usually forward momentum and damage to a tip will bend the wings close to where they attach to the fuselage. Composite aircraft, (think Cirrus) when they get a tip strike will buckle(actually de-laminate) the rear spar under the aft seats inside the fuselage.
Every Airplane reacts differently to a tip strike.
Sorry to be the bearer of bad news, but take another look. Also check your carry through spars inside the cabin.
The picture may "enhance" the view of the wrinkle, but it doesn't look all that great.
8451
Aircraft Type: Formerly a 120
Post by 8451 »
Deleted
8451
Post by 8451 »
Deleted
8451
Post by 8451 »
Deleted
Post by V529 »
The wing tip is a separate piece. My airplane was destroyed in a wind storm in 1991. I purchased a used set of fabric wings. On one of those I had to replace the wing tip. It's a very straight forward replacement, effortless actually. (when the fabric or metalized covering is removed :x ) Cessna did supply tips as "spare parts"........back in the day.
That being said, it's held on pretty stoutly. Double row of bolts perhaps.........I'll look at my airplane the next time I'm out there.
If you can find some way with a borescope to look out there..........I would try. Also run the borescope under the area where the wrinkle is. The two areas that show damage (typically) are where the wing rib meets the spar(common enough that Cessna came out with "L" shaped doublers to rivet in those locations) and the spar itself.
Post by V529 »
Where the wing bolts to the fuselage is pretty stout. I would look for damage either outboard or inboard of that location.
8451
Post by 8451 »
Deleted
4945
Occupation-Interests: Retired Congressional Staff, Navy Reserve Retiree, Former P-3 Flight Engineer, Former aerospace technician
Post by 4945 »
V529 wrote: ↑Wed May 20, 2020 8:25 am The two areas that show damage (typically) are where the wing rib meets the spar(common enough that Cessna came out with "L" shaped doublers to rivet in those locations) and the spar itself.
I've been trying to find pictures of those doublers, which had been posted on this forum in the past. I believe those were part number 10004-58. I need about 4 or 5 of them and can't find them anywhere. I could easily make them if I could find a pattern or just a photo with some scale.
Gary
atypicalguy
Post by atypicalguy »
One of my tips has an imperfect repair on it; metalized wing. It flies fine, but looking at it bugs me. So if I want to make it perfect, is the program to deskin, inspect and then buy another wing to harvest the tip ribs from and replace parts as needed? Just wondering what people typically do to obtain the parts. Maybe I should let whoever does the repair figure that out; just wondering how hard that sort of stuff is to find.
8281
Post by 8281 »
Which side are you refiring too? right or left?
I have parts for one side that was metalized but will have to look!
Some pictures of your wrinkled tip would be helpful.
