Trim Wheel decals
Aircraft Type: C140A
Re: Trim Wheel decals
Post by 8474 »
Hi Doyle, can you check your PM's. I can send you a set, just need your mailing address.
Blaine:
Mine have arrived! Understand the horse went lame coming over the TN mountains, so was delayed! :D
They look great. Thanks,
Edd
Post by 8474 »
Thats great Edd, glad you like them.
Aircraft Type: '48 140
Post by 6339 »
The Florida sets arrived yesterday....they’re perfect. Thanks again!
Steve
Post by 8474 »
Thats great Steve, will be nice to know so many 120/140's will be sporting shiny new trim labels :D
Esmiol
Aircraft Type: C120
Post by Esmiol »
Thanks Blaine!
Now I got to vacuum my plane.
Trim Decal sm.jpg (108.78 KiB) Viewed 40100 times
Post by 8474 »
Thanks Matt, I see your Take Off range ( neutral) is a lot further aft than mine, I have an A model so maybe thats why.
Esmiol
Aircraft Type: C120
Post by Esmiol »
I wouldn’t think the pointer is very accurate plane to plane.
If you want I can take a picture of the trim tab.
Even that will very with cg and thrust differences between planes.
8474 wrote: Fri Jun 26, 2020 11:28 am Thanks Matt, I see your Take Off range ( neutral) is a lot further aft than mine, I have an A model so maybe thats why.
I think mine's about where the "N" in Nose is on the decal. AFAIK, it's correctly rigged; I did it myself!
Post by 8474 »
I'm going by the slot and as you can see in my first post I'm about 1/3 back from the front, I see Matt is more like half way. I have no idea if mine is rigged correctly, seems to fly fine, but that the extent of my knowledge about the rigging.
