Exhaust AD 62-24-03
46cessna140
Exhaust AD 62-24-03
Post by 46cessna140 »
AD 62-24-03, effective Nov 21, 1962 addresses modifications for attaching the heat muffs to the exhaust stacks of Cessna 120/140/140A/Luscombe 8E/8F aircraft by following McKenzie Aircraft Repair Service Bulletin number 1 dated Sept 6, 1962. The Flight Standards District Office is unable to locate the McKenzie service bulletin. The AD addresses cutting off the heat muff attaching straps and attaching the muffs per the McKenzie service bulletin. If anyone knows how to obtain the service bulletin or the modifications involved, I would appreciate your feedback. Thank you
Aircraft Type: 48 140 C90
Re: Exhaust AD 62-24-03
Post by 6898 »
Found this if its what your looking for?
FAA AD 62-24-03.pdf muffler.pdf
(91.68 KiB) Downloaded 667 times
Do you have a Lycoming engine installed under one of the McKenzie approvals? If not, it doesn't apply.
The Cessna McKenzie STCs were acquired by Gus Warren, I think. Maybe he has the service bulletin, too.
