If elevator and trim tab travel are set according to the Aircraft Specification, then, when the elevator is neutral (faired with the stabilizer) and the trim tab is also neutral (fared with the elevator), it is in the takeoff position.
This information can also be gleaned from the Operation Manual.
Trim Wheel decals
Re: Trim Wheel decals
- Name: Matt
- Aircraft Type: C120
My plane had the pre AD elevator spar cracks when I bought it.
Ended up replacing the elevators with ones with reinforcements/brackets to comply.
I would not be surprised if the IA miss rigged the pointer, he missed the AD @ annual.
Not to single out that individual but the plane was in annual w/cracks when I bought it.
Ownership is so much fun,
Matt
Matt
- Name: Blaine F
- Aircraft Type: C140A
Thanks John, I will double check that when I get home. Thats the nice thing about ownership Matt, learn something new everyday
- 8233
- Name: David Freeland
- Aircraft Type: 1946 C120
Hi Blaine,
Can you confirm mine were mailed?
- Name: Blaine F
Hi David, yes all who requested decals got mailed out, looks like with all thats going on some are taking longer than others to arrive. I'll be home in a week, if you don't see them by then let me know and I'll send another.
- Name: Greg L
- Aircraft Type: 1948 C140/C-90
- Occupation-Interests: retired
I just saw this post. My decals are beyond worn...
If you do another production run, please count me in of a set!!
Greg Lennox
Greg Lennox
1948 Cessna 140 N3693V
Serial Number 14969
Based at KCMA
Serial Number 14969
Based at KCMA
- Name: Blaine F
Hi Greg,
send me a PM with your address and if I get enough orders ( I have 2 now) I will get another batch.
- Occupation-Interests: Barely employed Dash 8 Pilot
I'll take 2 sets if you produce another run.
Steve
Steve
- Name: Blaine F
Hi Steve,
Looks like I have enough orders now for another run, drop me a PM with your mailing address and as soon as I get them done I will send out.
Will do. On my iPhone now but I’ll send you a message when I get home.
