Primer stripper
Primer stripper
I am doing a total overhaul on a 1946, 140.
The strippers that I have tried worked ok to get the paint off but not doing a good job on the primers.
There are both grey and green primers that I would like to get off.
Does anyone know of a brand of stripper that will work to get these off?
Re: Primer stripper
Try acetone and elbow grease. Scotch-brite helps but will leave scratches in the surface. Or, try putting the stripper on and covering it with Saran wrap so it doesn't dry out. Let it sit for several hours.
Re: Primer stripper
Sounds like epoxy primer. Might try some MEK just in a small area to test - MEK is very toxic so protect yourself - try John C acetone first. Acetone is finger nail polish remover but very watered down now.
Re: Primer stripper
Thank you gentlemen.
I will let you know how it goes.
Re: Primer stripper
Acetone will dissolve epoxy, but it ain't easy...
Aircraft Type: C140A
Re: Primer stripper
Post by 8474 »
6643 wrote: Mon Jul 20, 2020 7:04 am Acetone will dissolve epoxy, but it ain't easy...
I can attest to that, I tried everything ( stripper, acetone, MEK, heat, etc) and was not able to even put a dent in some cowl grills I got from a friend of mine that were painted with Imron. Granted I didn't do the saran wrap John suggests, that might have done it. I ended up getting them bead blasted clean, which worked fine although left them with a slightly rough finish.
regular122
Aircraft Type: 1948 C140 C90
Re: Primer stripper
Post by regular122 »
I had / have the same issues. Had to plastic bead blast the instrument panel covers. On the gear legs, struts and other metal areas, we are just smoothing it out and painting over it. So far, we've been able to get all the paint off the fuselage and control surfaces with JASCO Premium Paint & Epoxy Remover. You can see the details of that in 'The Rebirth of Cessna 140 NC3771V' thread in the Member Aircraft and Project Showcase.
After stripping
After Plastic Bead Blast
The plastic beads reduce the weakening of the Alclad surface. Steve
Re: Primer stripper
regular122 wrote: Mon Jul 20, 2020 3:04 pm I had / have the same issues. Had to plastic bead blast the instrument panel covers. On the gear legs, struts and other metal areas, we are just smoothing it out and painting over it. So far, we've been able to get all the paint off the fuselage and control surfaces with JASCO Premium Paint & Epoxy Remover. You can see the details of that in 'The Rebirth of Cessna 140 NC3771V' thread in the Member Aircraft and Project Showcase.
Where would I find the Jasco remover?
I was not able to find it on Amazon.
What does the can look like?
regular122
Re: Primer stripper
Looks like this if you can find it. Steve
Re: Primer stripper
8342 wrote: Mon Jul 20, 2020 6:36 pm Where would I find the Jasco remover?
Home Depot
