That's the official name for the ball in the instrument panel that the control yoke tube goes thru.
What type lube is best for the wooden ball and socket? Mine had a caked on black paste that seems to have some graphite in it. It was definitely not doing any lubricating!
This probably has been discussed, but I couldn't figure out how to define it for a search that resulted with posts.
Thanks.
Steve A H
"Ball - Control Tube Instrument Panel Guide" Lubrication
8424
- Name: Steve A H
- Aircraft Type: 1950 C140A
- Name: Mac Forbes
Re: "Ball - Control Tube Instrument Panel Guide" Lubrication
I use LPS#2... sparingly. That's worked well for me.
7392
I use a silicone spray. Apply to my finger tips and spread it on the yoke tube. Really works well and doesn't create a build-up
of gunk on the tube. Use it on the primer plunger also. It won't attack the o-rings.
Larry Surratt
C-140 1946
89011
26R
Larry Surratt
C-140 1946
89011
26R
It's phenolic. There used to be a Teflon replacement part. It was available from Wag-Aero. STC SA666NW. I can't find it any longer.
- Name: Steve A H
Thanks for the replies.
I have a can of LPF-2, I'll give that a try. I'm sure silicone would work nicely too.
Thanks for the correction on the ball material, John. It looks just like a hard wood grain on the outside, but it can be seen that it is phenolic in the tube hole.
The 170 folks were buying Delrin® Acetal Resin balls from McMaster-Carr and having them bored, but I don't have a way to get one bored. Univair has the part for $185! Mine aren't sloppy, just were gunked up so they wouldn't move in the socket.
Here's the McMaster-Carr site. Part number is 9614K39.
https://www.mcmaster.com/standard%20plastic%20balls/
Steve A H
Steve A H
- Name: Mac Forbes
FWIW, @ Ebay: Item # 264552689277. $ 0.99 each, 4 available (I'm not the seller).
Mac
Mac
8424
- Name: Steve A H
Hi, Mac!
Thanks for the Ebay find. The seller says the I.D. is 1 inch. The ones in our planes have aprox. 3/4 inch I.D. Mine are .780...probably a little oversized due to 70 years of wear! The control wheel shaft is .750.
Steve A H
Steve A H
- Name: Mac Forbes
His measurements may be approx guess(?)...in any event, they fit mine perfectly/same size as my old ones (were in 1946). FWIW -- I'm not selling anything
. Mac
6863
- Name: John Kliewer
Steve, you asked about a lubricant that works. I have found that the windshield cleaning spray Clear View works for me if I moisten a rag with it and rub it onto the yoke shaft. It takes several applications of this over a series of flights to get things limbered up nicely.
John Kliewer
4390
- Name: Franklin B
viewtopic.php?f=8&t=671
I've made many of them, they work great.
BTW, I use silicon spray to lube the yoke shaft.
