flying with windows open
thing73
Post by thing73 »
is it ok to fly with the windows open??? The mechanism is pretty spindly.
8359
Re: flying with windows open
Post by 8359 »
I do often, but I'll wait till I get to cruise flight to do so. Just be aware that anything on the shelf behind you will blow around. My windows open all the way and rest up against the wing.
Aircraft Type: Cessna 120
Post by 7896 »
My passenger's side window was screwed shut and there was no latch when I purchased my 120. Later, I discovered that the hinges were in place, and the window swung open easily. I added C150 style latches on both sides and now open the windows in flight regularly. I also added a rubber strip on the outside of the lower frame in case it bumped the wing.
Maybe the best part is the fresh air while descending and landing on +90 degree F days. Hands down better than the original configuration.
I too wait until I'm cruising before switching to the open configuration.
Cheers,
N76219 Window Open.jpg (86.1 KiB) Viewed 4231 times
Michael Haas
'46 120 - N76219
Home Base: W96 (Quinton, VA)
4290
Post by 4290 »
I have a very original 120 with the original window latch on the pilot side. I taxi, take-off, climb, cruise, descend, land, etc. all with the window open. No buffeting or anything on the window/latch; but as others have mentioned, stuff on the hat shelf will get blown around if not secured.
mdtrn
Post by mdtrn »
For what its worth, a buddy has a 56' 172 which appears to have a similar latch system to the 120/140s. He has pulled the rivet on the bracket of the door. Damage indicates the rearward airstream pulled the scissors too much. After 64 years though I don't think you can complain too much.
