140 with 150 tail?
Re: 140 with 150 tail?
Post by 6183 »
V529 wrote: Tue May 19, 2020 3:13 pm .........we might have a cottage industry in the making! ;)
Don't think so my friend!
klyde sessna
Aircraft Type: C120
Post by klyde sessna »
Notice the large door opening? Not an early straitback 150, since they all had 120/140 doors. Must be a 1962 or 63.
8424
Name: Steve A H
Aircraft Type: 1950 C140A
Post by 8424 »
'60- '65 150's have the tapered door. Square door started in '66 with the F model.
Omni-Vision started in '64 with the D model.
The straight back with the square door didn't happen from the factory.
There was some really creative assembling to get this combination in one plane for sure!
I sure would have enjoyed having this plane...just for the conversational value!
Steve A H
Post by 4004 »
Might want to quieten down - if an overzealous person (big brother) happens to be monitoring, FAA can always require a "conformance check" and pull the AW certificate unless all mods are properly documented! 2C.
a64pilot
Post by a64pilot »
I think you May have found a “Texas tailwheel conversion” they aren’t as rare as you would expect and the ones that really look odd are the newer 152’s with the rear window and modern shaped tail
https://taildraggeraviation.com/lowe-aviation-home/
klyde sessna
Aircraft Type: C120
Nope. This one has the Bolen/Lowe tailwheel conversion. (Uses C-120/140 gear and tailwheel bracket, unlike the Texas STC.). As noted, there is a whole lot of different years and parts joined together here in this bird. Some early straitback joined to some later square door cabin with 140A or 150 wings. Love to see it's paperwork!
8474
Aircraft Type: C140A
Post by 8474 »
klyde sessna wrote: Tue Sep 01, 2020 7:03 pm Nope. This one has the Bolen/Lowe tailwheel conversion. (Uses C-120/140 gear and tailwheel bracket, unlike the Texas STC.). As noted, there is a whole lot of different years and parts joined together here in this bird. Some early straitback joined to some later square door cabin with 140A or 150 wings. Love to see it's paperwork!
Very hard to tell from that picture, but it doesn't look like it has fowler flaps, so I'm guessing an A wing with different tips.
