Yoke Mounted PTT Switches
Re: Yoke Mounted PTT Switches
Post by a64pilot »
I put a simple momentary switch on the panel, happened to be a starter switch for an R-1340, but any switch will do.
It’s not difficult to push a button, remember back in the day they had to remove a Mic from its clip and hold it to their mouth to speak, so a button on the dash is no issue.
If someone were to drill the tube, just be sure to debur the hole, almost certain our C-210’s tube was drilled and several wires were run through it. A C-210 is much heavier on the controls than a 140.
phil123
Aircraft Type: C140-O200
Post by phil123 »
Here is an option, use an adel clamp and sandwich the clamp around the yoke with the ptt. Use Tefzel wire 3 in 1 or similar and feed it through the yoke tube with a small hole drilled on the back side, the front side is open behind cover. Must be careful that wire does not interfere with other things with control yoke movement, it is doable by owner but you may get an a/p involved for safety reasons. Works good with less wire clutter. :)
8424
Name: Steve A H
Aircraft Type: 1950 C140A
Post by 8424 »
My son's C180 has the PTT switch about an inch above the throttle. It's a really good place to have it...works whether flying from the left or right seat. The only thing that keeps me from doing that is having to drill in the plastic trim piece. I don't want to crack it. I have a couple of plexiglas bits, but not sure if they are the right size.
If I decide I'd like to drill the shaft, I'll talk to my IA for advice, since he'd be the one to sign it off. The Adel clamp looks nice.
Thanks for the suggestions!
Steve A H
8424 wrote: Sun Nov 01, 2020 7:07 pmI don't want to crack it. I have a couple of plexiglas bits, but not sure if they are the right size
A step drill works well in plexiglass. "One size fits all".
8424
Name: Steve A H
Post by 8424 »
Thanks, John, for the suggestion. I have a step drill, but would have never considered using it on plexiglas. I've got some scrap pieces, so I'll give it a try.
Steve A H
Use the plexi drill to make a pilot hole as sometimes the step drill is harder to center. Then, enlarge the hole as necessary with the step drill.
8424
Name: Steve A H
Post by 8424 »
OK, I'll do that. Thanks.
Steve A H
Post by 6843 »
I've had the Talk-n-klip for more than 10 years (Also made by a member. Find on the member products page). I love it and it has not given me a moments problem.
I highly recommend. https://cessna120140.com/wp-content/upl ... -n-nav.pdf
Dave Sirota
Dave Sirota
'46 C-140 N89654
'96 Hatz N24B
KRYN
chewie
Post by chewie »
Great ideas guys, thanks! Steve, no issue at all, I'm just looking for ideas on this thread so this is perfect.
Mark
Mark Johnson
wccborn
Aircraft Type: 1946 C140
Occupation-Interests: fly4fun
Post by wccborn »
I just made a little loop out of aluminum and ran the wire through the yoke. A little heat shrink and some rubber grommets added a nice touch.
image2 (1).jpeg (77.63 KiB) Viewed 5318 times
image1 (1).jpeg (78.89 KiB) Viewed 5318 times
