Extended luggage compartment
fastj22
Post by fastj22 »
Recently purchased a 1948 C140 that has an STC'd extended baggage area. I'm going to redo the interior and really don't need the extra space. However, when they did the STC, they removed the aft headliner support and compartment panel. I have only seen the video on replacing the headliner where this support is referenced. I assume a bulkhead panel can be fabricated out of .025 alum. What is the cross member made of? Looks from the video as a c channel.
Re: Extended luggage compartment
Post by 8359 »
I can't help with your question, but would you mind posting photos of what the extended baggage area looks like? I haven't seen that before for the 120/140.
meloosifah
Post by meloosifah »
Post a copy of the STC too!!! I would love to see the pictures as well.
meloosifah
I don’t know what gauge, but it is a very thin C channel in my late model 140. I can get dimensions if you need them. Send me a pm with a phone number and I can take pictures and text them to you in the AM.
fastj22
Post by fastj22 »
I misspoke, it was not an STC but a 337. Attached are some pictures.
fastj22 wrote: Sat Nov 07, 2020 11:57 am I misspoke, it was not an STC but a 337.
Do you mean a field approval? (An STC still requires a 337.) Can you post a picture of the front of the 337?
fastj22
Post by fastj22 »
Here is the front sheet.
A oldie! The stamp and signature in block 3 is a field approval.
Occupation-Interests: Semi-Retired A&P
Post by 5099 »
Interesting. You can carry 33 pounds of baggage but not a passenger? ;)
America, Love it or Leave IT!
c180guy
Occupation-Interests: Scratch head....tired or retired right now.
Post by c180guy »
Even more interesting, you can carry the equivalent of 90 lbs of auxiliary fuel in what I assume, the 80 lb baggage area. That's in addition to the 33 lbs in the extended baggage. At least that's my take-away from the 337.
Question to the owner, is the battery box in the stock location? Verses being moved to either within the front baggage area or on the firewall?
When I saw the first post, I assumed it would peak a lot of interest. It did mine!
And thanks for posting the information! I for one appreciate it and I think others here do too!
