Saw this on Backcountry Pilot... https://backcountrypilot.org/community/ ... anes-24653
For those who aren't up to speed the bracket between the seats originally was aluminum and later changed to steel. Apparently there was a second failure fatality and the feds are showing a renewed interest in the part as of 12/14/2020.
Revisiting Seatbelt bracket 0425132
- Cessna_Seat_Belt_Mounting_Bracket_ACS.pdf
- (103.83 KiB) Downloaded 1143 times
6930
- Name: Mike
Re: Revisiting Seatbelt bracket 0425132
I checked and mine is steel, though it doesn’t have the relief cut shown in the SB. Assuming it is ok.
Mike
Mike
tonycondon
- Name: Tony
tobyadobe
Where can you buy steel seatbelt center brackets for C140s?
