WTB Flap Control Assembly
Post by 8434 »
Hi,
I'm in search of a flap control assembly. Its the part that is riveted to the flap that connects to the Torque tube.
Cessna PN 0425118
If anyone, especially those in Canada have one kicking around I would gladly buy it. Its the left one. the PN for the right is the same with -1 at the end.
Marshall
Re: WTB Flap Control Assembly
Univar has them. A bit pricey at $195, but you will not have to worry about rivet holes lining up.
And no preexisting wear in the flap connect hole.
Post by 8434 »
Yeah I saw that, thought I'd see what was around first.
2356
Post by 2356 »
Univair will be your best choice.
They're pretty easy to repair; just a bit of tubing with a slot milled in it, welded to a bracket.
