Seat Belt Brackets
Re: Seat Belt Brackets
These are my Hookers. As far as I know all of Hooker's belts for our planes are made this way(?)...and will slip right into the bracket.
Post by a64pilot »
I never realized the hold down piece was split like that enabling the belt to be slipped on.
Hooker harnesses I have have this type of end, that I can cut off with my die grinder, but my belts are 3” wide, which is I think wider than the hold down?
Probably can still fit them on though, what is the width of the belt you have?
a64pilot wrote: ↑Sun Dec 20, 2020 3:37 pm I never realized the hold down piece was split like that enabling the belt to be slipped on.
Two inches.
8359
Post by 8359 »
Anyone have any leads on a new manufacture replacement part? Not really keen on replacing with a used part with unknown history.
8359 wrote: ↑Tue Feb 02, 2021 9:38 pm Anyone have any leads on a new manufacture replacement part?
Refer to Post #7.
8359
Post by 8359 »
6643 wrote: ↑Wed Feb 03, 2021 7:02 am
Refer to Post #7.
Ah thanks. I thought that was used, figured there’s no way anything new in aviation could be “only” $70, ha.
Nope! Yingling is a Cessna dealer. (Used is a lot more, $250 quoted in Post 5.)
8359
Post by 8359 »
So I called about that bracket, Yingling said that part is on a 4 week lead time just to find out if it's available. At that time they'll set actual pricing if they can get it. Will keep searching around. I'm sure with the AD out it'll get a little harder to find.
8359 wrote: ↑Wed Feb 03, 2021 5:23 pm So I called about that bracket, Yingling said that part is on a 4 week lead time just to find out if it's available. At that time they'll set actual pricing if they can get it. Will keep searching around. I'm sure with the AD out it'll get a little harder to find.
Just to be clear it's not an AD.................yet. I wouldn't be afraid to utilize a used one, steel is significantly better than aluminum even if it's used. Just keep shopping and one will turn up.
Try these guys. They claim to have 172 of them:
Vendor Name: ULTIMATE AVIATION SOLUTIONS
Contact Name: SALES
Email Address: sales@myuas.aero
Phone Number: 305-394-9458
Fax Number: 305-499-9922
Address1: 11251 NW 20th STREET
Address2: SUITE 111
Address3:
City: MIAMI
State: FL
Zip: 33172
Country: United States
Part Number: 0425132 Alt Part Number:
Description: BRACKET Source: Direct Match
Qty: 172 Cert Source:
Condition: NE Tag Date:
