Scott Brake Cylinder
Post by 8209 »
Does anybody know where I could get the o rings and u cup to rebuild my Scott brake master cylinder?
Brent
4751
Re: Scott Brake Cylinder
Post by 4751 »
Univair.
If your cylinder is original equipment, searching "brake master cylinder" may help zero in on what's needed, then Univair or Spruce or others can supply. In looking back a bit there's this related post by one of our Moderators: "AN6227-7 or MS28775-012 (o-ring). The cylinder is a very simple design and the o-ring is the only wear part. There is a little pin that cocks the o-ring at the top of the stroke to allow fluid in and out of the reservoir. The o-ring takes a set .." Hope that'll help. Mac
8209
Post by 8209 »
Thanks for the info guys.
The original master cylinders are Goodyear, not Scott.
