Seeping Fuel Quantity
6555
Aircraft Type: c140
Re: Seeping Fuel Quantity
Post by 6555 »
Thanks Mac, do you know the PN for the gasket?
I think it's Spruce Part# 15-4 (MFR Model# 0015-00004). I've got one "somewhere" & will look to see when I get back into the hangar. You can give the folks @ Spruce a call & they'll know -- it's a Rochester part. Mac
Aircraft Type: C140A
Post by 8474 »
https://www.aircraftspruce.ca/catalog/pnpages/15-4.php
This is the one, from the ACS Canada site, but the same part number that Mac said.
Schematic from Rochester to confirm dimensions, drawing number 0015-00004 'Senior' gasket
fuel_gasketRochesterSenior.pdf
(111.78 KiB) Downloaded 837 times
Aircraft Type: 1946 C120
Post by 8233 »
PN 15-4 was what I used from Aircraft Spruce. Here is also a PDF I found for the newer gauges.
Rochester-Jr-and-Sr-Bolted-Gauge-Installation.pdf
(104.1 KiB) Downloaded 1413 times
6555
Aircraft Type: c140
Post by 6555 »
Thanks, my spelling wasn't so good, the part I can't find is the gasket, I found the floats ok.....John
6555
Aircraft Type: c140
Post by 6555 »
OK Ill just call Spruce...Thanks
Good deal. ...and, just to emphasize David's admonition not to over-torque the screws when re-installing with the new gasket. There are a number around (Ebay, fly markets) that have been hunkered down to the point of cracking, some no doubt in attempt to stop leaks. Once cracked, the damage is "permanent". Mac
Post by 8233 »
6555 wrote: ↑Fri Jan 08, 2021 10:08 am Thanks, my spelling wasn't so good, the part I can't find is the gasket, I found the floats ok.....John
Here is the link to the gasket:
https://www.aircraftspruce.com/catalog/pnpages/15-4.php
6555
Aircraft Type: c140
Post by 6555 »
Thanks Again guys I got the rubber gasket from Spruce would you use a gasket sealer when installing it?
