Seeping Fuel Quantity
6555
- Name: John Shahkey
- Aircraft Type: c140
Re: Seeping Fuel Quantity
Thanks Mac, do you know the PN for the gasket?
- Name: Mac Forbes
I think it's Spruce Part# 15-4 (MFR Model# 0015-00004). I've got one "somewhere" & will look to see when I get back into the hangar. You can give the folks @ Spruce a call & they'll know -- it's a Rochester part. Mac
- Name: Blaine F
- Aircraft Type: C140A
https://www.aircraftspruce.ca/catalog/pnpages/15-4.php
This is the one, from the ACS Canada site, but the same part number that Mac said.
Schematic from Rochester to confirm dimensions, drawing number 0015-00004 'Senior' gasket
- fuel_gasketRochesterSenior.pdf
- (111.78 KiB) Downloaded 776 times
- 8233
- Name: David Freeland
- Aircraft Type: 1946 C120
PN 15-4 was what I used from Aircraft Spruce. Here is also a PDF I found for the newer gauges.
- Rochester-Jr-and-Sr-Bolted-Gauge-Installation.pdf
- (104.1 KiB) Downloaded 1314 times
6555
Thanks, my spelling wasn't so good, the part I can't find is the gasket, I found the floats ok.....John
6555
OK Ill just call Spruce...Thanks
- Name: Mac Forbes
Good deal. ...and, just to emphasize David's admonition not to over-torque the screws when re-installing with the new gasket. There are a number around (Ebay, fly markets) that have been hunkered down to the point of cracking, some no doubt in attempt to stop leaks. Once cracked, the damage is "permanent". Mac
- 8233
6555
Thanks Again guys I got the rubber gasket from Spruce would you use a gasket sealer when installing it?
