In the pic below, there is a disc screwed into the rear of the T and B (Vacuum) What is the disc for?
Thingy on top of Turn and Bank
- Name: Jody
Re: Thingy on top of Turn and Bank
God that thing looks as old as the WWII instruments that were in mine.
My guess is that it’s a valve so that you can change the amount of airflow through the instrument. But that’s a guess.
I’ve never worked in a Vacuum T&B, does it only have one hose that goes to it? If so then could the disk hold an air filter?
- 8102
- Name: Gregg T
- Aircraft Type: 47 Cessna 140
- Occupation-Interests: Retired Aerospace/Defense Engineer
I found this image online from a 1940's manual. Looks like the "thingy" could be a filter.
Gregg
Gregg
- s-l1600.jpg (306.36 KiB) Viewed 2322 times
- Name: Mac Forbes
Yup!
Take the staples out and change the paper with bits cut from a coffee filter.
