I don't believe a sealer was used when mine was installed.
Seeping Fuel Quantity
- 8233
- Name: David Freeland
- Aircraft Type: 1946 C120
Re: Seeping Fuel Quantity
- Name: Jody
If I were to use any sealer, it would only be b2 fuel tank sealer.
B2 refers thickness and work time, a brand name is pro-seal, but it’s what it used to seal fuel tanks so therefore it’s impervious to fuel, and made specifically to be used in fuel systems
Any form of silicone for instance is absolutely unsafe in aircraft fuel systems, I’m sure the FAA has a SAIB on sealants used in fuel systems.
Best not to use anything
- Name: Blaine F
- Aircraft Type: C140A
I had one of my gages out recently and used a new gasket when I put it back in and didn't use any kind of sealant, no leaks.
- Name: Mac Forbes
...didn't use any sealer on mine. Mac
If you really want something, use fuel lube (EZ Turn)
